Convert Meraki Access point from DHCP to static IP via API
Manumon
HI ,
Is it possible to change the IP address of all access points onboarded in Meraki Dashboard which is currently dynamic to static instead of doing it manually one by one via GUI.
marce1000
 - Are  you sure you wan't to go down that path : static IP doesn't scale ,  using DHCP is better , provides flexible management and easier if an AP-subnet would need an address change (e.g.)
  M.
If they weren't already added to the networks, you could use the bulk network creation tool.
https://documentation.meraki.com/General_Administration/Templates_and_Config_Sync/Using_the_Bulk_Net...
One option would be to remove them from the networks, and then re-add them using the above tool.
TBHPTL
DHCP. This is the way. I have spoken.
Seriously, you would be better of with IP reservations.  (Fixed IP assignment in Meraki speak)
