Configuring Rules for Meraki GUEST Network (Internet-Only Access)
MauroF
Question: If I want users on a Meraki GUEST (SSID) network to access only the internet:
1) where should I configure the rules? Under the Wireless section or the Security & SD-WAN section?
2) Is there a priority of rules?
3) what happens if i configured the SSID to deny traffic towards LAN but in the firewall rules there is an Allow Guest-->Any?
Thanks in advance
2 Replies 2
Mloraditch
1) It depends on how you want to set it up. If I'm NATing my guest traffic to the AP, I set up the rules on the APs. If I'm dropping off to VLAN I setup the rules in a Group Policy on my MX associated to that VLAN.
2) Wireless would be processed first then MX rules if you had both.
3) As wireless is processed first that would block traffic to any RFC1918 subnets.
RaphaelL
Hi ,
Deny LAN won't deny access to the Internet. If you have a MX and MR , I would put the rules on the MX.
1- Deny LAN on the MR
2- Deny RFC1918 on the MX
3- Allow "internet" on the MX
That is how we have our Guest SSID configured.
