Configuration is out of date. (Meraki AP)
erhanevgin
Hello Guys.
Do you have any idea for the below issue?
2 Replies 2
Hi @erhanevgin, have you tried a factory reset?  A while ago I had the same problem, and to solve it, it was necessary to reduce the number of characters in the network name. Support explained why, but I don't remember exactly why.
erhanevgin
@alemabrahao thank you for your answer but this network has been working since 2020. I think our problem is different.  We are waiting for the support engineer's answer. I will share it with you.
regards.
