Combined networks with WiFi template
Tuvestam
I have combined network without Template (MX and Switch) now i would like to add a WiFi that is connected to a WiFi template. Is this doable.
5 Replies 5
If you are asking can you have a combined network that is a template - yes.
Tuvestam
No can I have a WiFi templet (only WiFi) in a combined network. All my WiFi should be the same but switches and MX is very different in every network.
Nash
If I knew for sure that I did not want templated changes on my switches/firewalls, regardless of whether or not I could use a wifi template on a combined network... I wouldn't. I don't like the risk of changes rolling out on equipment that needs to remain unique.
So what can you do?
I see two options:
  1. Split each location's wireless network off into an individual network, leaving your other Meraki equipment in a combined network. Apply template to these individual wireless networks.
    1. Problem: You lose easy visibility through the stack.
    2. Problem: That's potentially double your networks, which is a mess.
  2. Use the API to copy-paste SSID changes across your networks every time you need to make a change. This also allows you to exclude networks if you run into a case where Networks A - F need a change, but Network G doesn't.
I'd go the API route, because I prefer to do things with code. I have in fact gone the API route. It's pretty easy.
If you have a small number of sites, you could also put all the APs in a single WiFi network.
I have one customer with around 400 APs spread over 200 sites that use a single network for all of them.  In this case, they did this because of the way they wanted to use location analytics.
Nash
That's true, but I admit to really hating this solution. This is partly because my clients always creep into wanting exceptions for this place but not that one, and I have to implement them. That's a my-customers problem tho.
