Combined Network Option
Santhosh29
In a customer network , a dashboard network has firewall, wireless, switch, camera. If I place them in a combined network they all should be in same vlan. Is that correct?
If I have more than one access points ,having different ssid . I can't place those AP's in combined network. Is that correct?
rhbirkelund
You can do just whatever you like - put it all in a single VLAN, or create VLANs for every type of device.
You can also have as many Access Points in a Network as you want. They will all broadcast the same SSIDs.
2 Replies 2
rhbirkelund
You can use tags and "SSID Availability" to make some SSIDs appear on only some APs.
https://documentation.meraki.com/MR/Other_Topics/SSID_Availability
