Cloning AP / SSID Settings
clambert
Is there a way yet to clone AP or SSID information from an existing configuration?
2 Replies 2
WadeAlsup
The closest thing I can think of would be Configuration Templates
Found under Organization -> Monitor -> Configuration templates
Found this helpful? Give me some Kudos! (click on the little up-arrow below) and If my reply solved your issue, please mark it as a solution 🙂
MilesMeraki
As-well as configuration templates you could also use configuration sync - https://documentation.meraki.com/zGeneral_Administration/Templates_and_Config_Sync/Cloning_Network_S...
