Meraki switches are compatible with any vendor AP's (assuming they use industry standard protocols) - To answer your question; Yes the Cisco AIR-AP1131AG-A-K9 is compatible with Meraki switches.
For Management (Configuration) you will be unable to manage and configure the Cisco AIR-AP1131AG-A-K9 from the Meraki dashboard and will therefore have to use it's respective management/configuration platform.
