Clients cannot connect sometimes
Wireless123
I'm having this issue currently with an MR32 model.
802.11 association rejected for load balancing
It happens where a user cannot connect when there are too many people in the room near the AP, but once everyone leaves, the wireless works for them.  This is the same results for others, for the past year and I haven't been able to figure it out.
Adam
Try turning off client balancing.  It has been causing issues for some people.
Wireless>Radio Settings and set Client Balancing to 'Off'
10 Replies 10
Adam
jdsilva
Wireless123
I will try this aftrerhours, as I'm not sure if the APs will reboot. Don't want users noticing.  Also, after I do this, what are your thoughs on "Layer 3 Roaming" for my APs?  I currently do "bridge".
Adam
So you have Layer 2 LAN isolation set to "Enabled"?
Wireless123
No, I have set to "disabled".
Wireless123
I've turned off "client balancing".  Lets see how today goes.
Adam
Thanks I'll be curious to hear how it works out.
Wireless123
No issues so far today.
Adam
Thanks, glad to hear it.  We've had some issues with balancing as well where clients will hold onto further less signal APs in lieu of ones that are closer.
Alex_B
This post is still helping...
I was having some issues with Barco Clickshare dongles connecting as they didn't know which AP to connect to. They are quite dumb devices that plug in to the laptop via USB and share screen to the base unit connected to the TV. As they don't have much processing power or anything like 802.11v I believe.
