We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
If the my RADIUS server connectivity is lost from the APs. What is the expected behaviour?
It is documented for the cloud Meraki RADIUS server but knobs are given as well. But no such knob exists for my RADIUS server.
https://documentation.meraki.com/zGeneral_Administration/Cross-Platform_Content/Behavior_during_Conn...
I was expecting Meraki APs to cache the credentials and still keep on continuing to authenticate users using either the RADIUS server in the AP or via fallback to cloud RADIUS. Is it possible?
Solved! Go to solution.
If the user is already authenticated then they will remain connected and working.
However roaming may or may not work, depeding on what kind of connection is used (WPA2-Enterprise mode, 802.11r, captive portal).
