Hi All,
I'm looking to order an outdoor Meraki MR76 AP with a Patch Antenna, both to be mounted on a Pole.
I'm fairly confident the AP can be mounted on the pole with what's in the box (mount that it comes with), I've got two omnidirectional antennas already (MA-ANT-20 Meraki Dual-Band Omni Antennas), just want to be sure what's needed for the patch antenna (MA-ANT-25 Meraki Dual-Band Patch Antenna)
Can't locate installation guides for the Patch Antenna, or confirm what's in the box (length of cables)? Or what mounting bracket to buy is needed? Or would the MA-MNT-ANT-2 work okay with it? Both AP and Antenna will be mounted to the same pole.
I'll be using the Dual-Band Patch Antenna and Omni-Directional Antennas together.
Thanks for the help.
Tom
![TomS24_0-1717602147081.png TomS24_0-1717602147081.png](https://community.meraki.com/t5/image/serverpage/image-id/37715iD013668C903F6F38/image-size/medium?v=v2&px=400)
