Cisco M44 showing as "already in use.
DIPAK1990
I have purchased a new Cisco MR44 device. It was added to another network once but was later removed from there. Now, while adding the device to a new organization, it is showing as "already in use." How can I whitelist it? I have also reset it, but it is still not working.
rwiesmann
The device seams still to be claimed...so you need to have the previous owner to unclaim the device.
Or I guess support could also help you
sorry wrong...meraki support can not help you...see following documentation
https://documentation.meraki.com/General_Administration/Inventory_and_Devices/Cisco_Meraki_Devices_p...
So you need to contact the previous owner
rhbirkelund
Most likely it was removed from the network, but still applied in the previous organization's inventory.
It needs to be removed from the organization inventory, so you'll have to reach out to the seller of the AP.
EDIT: I see I should have refreshed the thread before replying. 😉
Check this, it will help you.
https://documentation.meraki.com/General_Administration/Inventory_and_Devices/Using_the_Organization...
