Channel utilization is high
AsHik
We are using the MR-52 running with MR 25.13 version firmware.
the channel utilization for 5 band is going high nearly reaching 95%
What can we do to bring this to normal??
Note:-no nearby AP's channel are overlapping with this one..
8 Replies 8
SoCalRacer
is this Channel 5 or 5Ghz?
AsHik
its 5ghz
It would just be one of your clients.  Does the AP show lots of throughput?
AsHik
How to identify that client????
Sometime throughput is high ???
If you click on an AP you can see the clients and their usage.
AsHik
Hi ,
Ya ok,
But how to identify that particular client .
Since we have more number of user.
Regards,
Ashi
GIdenJoe
Have you tried another channel?
There could be non-wifi interference with a high duty cycle.
In case of high usage due to someone overusing it, then just put a per client bw limit.
AsHik
dint tried to change the channel.
Already have per client Bw restriction
