Change Meraki Email
Andy-Lee
Change Meraki Email
We're implementing a guest SSID which will use Meraki Authentication. We're testing now and want to amend the email which users receive.  I've looked on the dashboard but can't see where it would be set. Anyone know if this is possible? Even if we could adjust the regional settings to UK (i.e. spelling of "authorized", timezone).  Example of the email below.
BrechtSchamp
I'm afraid you can't edit either with the built-in Meraki authentication.
BrechtSchamp
@BrechtSchamp is correct, you can not edit it.  However you can change the language.  You do this on the page where you edit the splash page.
There is only one English though ... time for make a wish.
Andy-Lee
Thanks both for your input. Not the desired outcome, but an outcome all the same!
Thanks 🙂
PhilipSannwald
How is it, that this *still* can't be changed?
