Cant select Access Point channel
Adrian4
My access points are using a profile with channel width set to 40mhz (no template is applied) and auto channel.
I am trying to manually override the channel to a specific one, but it will only let me select 20mhz channel 😞
For example I cant select channel 102.
Anyone know whats going on?
5 Replies 5
If you select one 20mhz channel it will indicate  in blue what 40 or 80mhz channel will be used.
So if you select 36 it will use 38 at 40mhz
Adrian4
ah ok thanks! how very unintuitive lol
Adrian4
I set the channels but in the settings they are showing the 20mhz channel
I set 60 and 100 expecting 62 and 102 😞
and even more weirdly - when I run a wifi scanner I can see the BSSID of these AP's are actually 80Mhz wide!
Adrian4
has anyone else come across this before?
Adrian4
anyone?
