Cannot revoke a wireless client
Qing
Hi, I tried to enable captive portal login for guest, but cannot revoke the guest and let him relogin again. From the client monitoring page, the splash is "Not authorized", but the guest still can surf the internet. Please advise,thanks.
AjitKumar
Hi @Qing
I understand "Splash Page Frequency" settings might help you here.
Kindly check the following thread for more information.
https://documentation.meraki.com/zGeneral_Administration/Cross-Platform_Content/Splash_Page_Frequenc...
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
5 Replies 5
AjitKumar
Hi @Qing
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
Qing
Thanks for your advice. yeah, this maybe helpful. I will try it. But the problem is we cannot revoke the client under client monitoring page. Looks not reliable.
OddievenInc
Hi
I'm having the exact same issue. Were you able to revoke the client by changing the Splash page frequency? Thanks
Qing
same ,still cannot revoke the client from the network monitoring. Meraki bug!!!!!!!!!!!! Need expert to solve the issue.
Qing
shorten the splash page interval, can help a bit only.
