Backup Concentrator for Remote AP's
XtremeBaseT
We have remote users/sites that only have AP's with SSID's that tunnel back to our concentrator at our data center. That Concentrator issues DHCP and access to the network.
However we have a secondary data center that we will need to use for redundancy should their be issues at our primary. From what I can see, in order to use that secondary we have to manually log into the dashboard and change the Concentrator we want to use within the SSID configuration page on the AP network. There is no option for a backup/secondary Concentrator in case the primary is down.
Is there something I am missing or is this a feature that is currently not supported? If not supported, what's the best method to request it?
2 Replies 2
You could use a warm spare setup. If you have layer2 between dc's
XtremeBaseT
That unfortunately is not an option for us.
