- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Any Reference home deployment of Meraki that i can refer to?
I am moving to a new house in the next few weeks, want to set up new all Meraki network at that place. (currently, I use google onhub wifi at the current house).
I am checking if anyone has existing all Mearki home deployment best practices or references which I can refer to.
I am looking for potentially 2 MR33, 1 MX68CW-NA - integrated with Cisco Umbrella.
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
A lot of us do, thanks to free hardware aquired after webinars or courses or because the companies we work for deploy Z-series at home. A home isn't that different from a small branch. Although you might not want to go very deep into complex architectures. Perhaps you'll prefer to keep your network flat.
Keep in mind that a Meraki solution is not cheap for private use. It's really meant for companies.
Anything specifically you want to know?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks. Looking for which devices/models are used typically for home use.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I'm using MX64, MR33, MS220-8P. That last one is EOS and has been replaced by MS120-8LP/MS120-8FP.
If buying new I'm not sure I'd go for MX64 nowadays. I have a feeling it'll be replaced by the MX67. But indeed, it is a bit cheaper than the MX67.
As @DavidLowe already mentioned, If you're planning to combine the WiFi from the MX68 with the MR33's WiFi, I'd advise against it. They're configured completely separately and therefore don't play along too well.
Similarly don't expect the same features on the built-in switch of the MX68 as you would find on a separate Meraki MS switch.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
my inventory: MX64, MS225-24P, MR18, MR72
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
as @BrechtSchamp wrote, it isn´t really for private usecases, if you don´t have free hardware because of webinars / a company you work for.
Regarding to the Webinars/events I´ve got a MR42 / MR33 and a small 8P switch, but not in use at the moment. And when the the license will expire and I don´t get new 4free devices I will get back to something cheaper, tbh.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hey Santo!!
There are a few guides available on https://documentation.meraki.com/ sometimes focusing on each product.
MX quick start: https://documentation.meraki.com/MX/MX_Quick_Start
MR quick start: https://documentation.meraki.com/MR/MR_Quick_Start
There are a few MX deployment scenarios here:
https://documentation.meraki.com/MX/Deployment_Guides
I think the smallest one is aimed at a 'Branch' network rather than a home deployment. As such it assumes that there are more than MX in play, as it shows you how to set up Site-to-Site VPN's
Really though, it depends on what you want to do with your home lab.
Personally, I was happy setting up a couple of SSID's for the Family and for Guests and making sure that all IoT devices were VLAN'd off
One thing you will want to note is that the MX68CW has integrated wireless that will not play well with your other MR AP's I.E you won't be able to roam between the MX(wireless) and the MR's etc...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Santo,
works fine, I have a MX64 followed by a MS220-8P and two MR32 working at home.
Satisfies my needs 100% and I can even offer a guest WLAN for my friends. They love it!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
For home deployment there are a couple of gotchas
- IPv6, being deployed domestically by increasing numbers of ISP, is not ready for the big time as the MX does not really handle it.
- Multicast TV - again increasing numbers of ISPs are using multicast technology to distribute premium subscription-based content. The MX absolutely does not have the option of having an IGMP-proxy enabled. (it isn't difficult it is part of Debian releases).
Not coincidentally, these shortcomings are less pressing in US/NA than the rest of the world. I know several really large all service Telcos that have substantial managed services businesses. They would use Meraki stacks, if the MX was more closely aligned with current requirements.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
To keep costs down you could try Meraki Go APs, I have heard they are a good replacement for Google wifi.
The 68 is probably sized too big. I would say 67 or 64 should be good. The only reason I would recommend 67 is that if you are sure you will be using the LTE failover. If not I would go 64 to keep costs down and then go usb modem if needed at some point. Z3 would be an option, for about 10 devices, but looking at the current specs I am assuming that is too small.
Home Setup:
MX67
MS120-8P
Ubiquiti 24 PoE switch
3 MV12
3 MR33
5 SM licenses
