Hi
Is anyone else having problems finding some an Android app when in Meraki MDM?
We are trying to roll out a Vodafone app across Android phones, but we cannot find it within the Meraki MDM portal.
If we look on the Google Play Store site it is there, but doesn't appear when searching in Meraki MDM.
Meraki is saying it will investigate., but a week or so later - nothing.
This is ridiculous. It severely restricts the functionality of MDM if we can't use it to roll out apps and makes it not worth using.
Just wondering if anyone else came across this and if there was a solution.
