Adding Meraki to ISE
satyamothukuri
Hello All,
We are planning to integrate Meraki wireless network to ISE for authentication. I would like to know
1. Auth request will be from AP's?
2. Do we need add all AP's to ISE for receving auth. we have WLC's added in ISE, so want to know how we can add all AP's?
3. can we add Accounting Servers  also meraki? As in WLC we will add Authentication Servers and Accounting Servers.
Is there any document i can refer for the integration meraki wireless with ISE.
Thanks in advance.
2 Replies 2
m841
All of the reference material for ISE integration is on this single page that should answer all of your questions and run through the basic configuration on each side.
https://documentation.meraki.com/MR/Encryption_and_Authentication/Configuring_RADIUS_Authentication_...
Yes.
Yes.  Typically you just add the subnet.  This then covers all for the APs in one go.
Never tried.  Doesn't seem much point when you have the Meraki dashboard.
