Most of my collegues asking how much will be the coverage can get by the Meraki Access Points. For eg: MR28 will be connected upto ___ merters in diameters . Approximately we need to know all Access points will give coverage with respect to all factors.
Well you know it depends on alot of factors. Your endpoints, your environment and the type of applications you use will all have an effect on the effective usable range of the AP.
When I put an MR28 on an empty floorplan (open air) on a height of 2.4 meters height (ceiling mount) where I use a laptop as reference (-3 dB) I get a border of -67 dBm at +/- 40 meters from the AP in multiple directions and 30 in 1 direction. Do mind that this is the radius not the diameter.
if you want to achieve a good rf design (it's not all about signal strength) you should consider talking to a wireless consultant which can do a professional wi-fi site survey.
Site survey!!! Do not just rely on antenna patterns and data sheets. There are so many variables with wireless signal that the only answer is to get hardware onsite and work through your site.
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_4b898d8dad380","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_4b898d8dad380_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_4b898d8dad380_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_4b898d8dad380_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_4b898d211eb18","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
