AP is unable to fetch its configuration
Ahmed-Medhat
We have a problem regarding an MR33 access point , it is always in alerting repeater mode or totally offline , it also shows " This device is unable to fetch its configuration from the Meraki cloud. Please contact Meraki Support." message
I tried to hard reset the access point but it still the same
2 Replies 2
NolanHerring
Did you contact Meraki support?
Nolan Herring | nolanwifi.com
TwitterLinkedIn
SoCalRacer
Some troubleshooting info:
https://documentation.meraki.com/MR/Other_Topics/Troubleshooting_and_Replacing_a_Faulty_MR_Access_Po...
Here is some info on resetting:
https://documentation.meraki.com/zGeneral_Administration/Support/Resetting_Cisco_Meraki_Devices_to_F...
What color light/lights are you seeing?
You might try going static IP
https://documentation.meraki.com/MR/Monitoring_and_Reporting/Static_IP_Assignment_on_a_Cisco_Meraki_...
Another option is segregate it to completely different physical network and access the local status page to verify settings/config.
