AP doesn't see client authentication/connection attempt on SSID after a handful of failures
Crocker
Hopefully this is a simple enough thing and I'm just missing something obvious.
We have an SSID that requires a valid, domain-issued computer certificate to authenticate to. Occasionally, GP fails and doesn't properly configure the 'Network' in windows (y'know, like it doesn't set the security type to 802.1X, doesn't set the auth method to EAP-TLS, that sorta thing).
Fixing this via a group policy update is pretty quick and simple; However, in the few instances this issue has cropped up, I only see a handful of failed authentication attempts and then radio silence regarding whichever client is acting up. So, I'll see client JohnPublicPC fail 802.1X a couple times and then nothing else at all. Like either Windows isn't even attempting to join the SSID, or the AP is straight-up refusing to even listen to the attempt. Hopefully this makes sense...
Anyways, this 'lock out' seems to clear up within an hour or two and (assuming we've fixed the 'network' settings for the SSID in windows) everything works fine from that point forward.
5 Replies 5
The problem is more likely to be on the device side than on Meraki.
Have you checked your radius server logs?
Crocker
Yeah, totally blank there too - no further attempts after the couple tries.
I agree, probably some device-side thing...just I'm not aware of any mechanism for that in Windows. Hoped casting a net on the forums might fish up some clues.
Make sure you are running a current stable or better firmware on the AP.
You could try doing a packet capture on the AP on the WiFi side to see what is being transmitted (if anything).
Crocker
Not much useful coming out of a packet capture. All I see are probes, no actual attempt to connect. Bummer.
Sorry man - client issue.
