AI-RRM Early Access is extended to APJ and ANZ countries as well as new Meraki customers who uses India and Canada’s Meraki cloud region.
Figure1. One click AI-RRM enablement
Cisco’s AI-RRM is the industry’s only solution utilizing AI/ML-driven trend-based algorithms for comprehensive RF optimization, uniquely offering unified AI-RRM services across both OnPrem (Cisco Catalyst Center) and Cloud (Meraki) environments. Powered by the world’s largest Wi-Fi RF data lakes, AI-RRM processes extensive datasets, building advanced models that draw the best answers on your Wi-Fi interference and performance concerns.
Figure 2. Summary bar shows RF operational status such as RF heath, AP under interferences and client connectivity impact.
Cisco AI-RRM uses the most sophisticated AI/ML algorithm, designed for Wi-Fi optimization, using uniquely tuned reinforced learning and deep learning model. It overcomes limitation of snapshot-based RF optimization solution and provides the sustainable, ideal RF configurations maintains its config during the AI Busy Hour detection and off-hour optimization.
Figure 3. Busy hour improved with AI-RRM.
Cisco’s AI-RRM uses AI/ML-based trend data, enabling predictive, intelligent decisions for RF optimization, such as TX power control, channel assignment, bandwidth selection and Flexible Radio Assignment, minimize co-channel interferences and maximize RF capacity.
This approach allows AI-RRM to make not only the best decision for the present, but also optimizes RF configurations based on future predictions.
Early Access service will continue until Apr 30, 2025. during the Early Access service, all of meraki customers in the supported region can use AI-RRM without Advantage license.
