- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
802.1X Wireless Authentication to Azure AD
Hello Everyone,
I've been trying to put together a proposal for a customer to make sure when a user is let go, that they cannot reconnect. I read that you can do 802.1X authentication with the Meraki dashboard. Is it possible to use 802.1X authentication on an SSID to integrate with Azure AD using SAML SSO / Dashboard connection? I've read conflicting information on the forums and I can't mess with their infrastructure, unfortunately. They have no local RADIUS infrastructure, all machines are straight Azure AD Joined. Any insight is greatly appreciated.
Thank you!
Doug
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I believe it can be done using an Azure site-to-site VPN and/or Meraki vMX appliance.
The following blog (written by a Meraki engineer) provides some detail - Meraki MR 802.1X with Azure Active Directory – APICLI
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
