802.11r OTA or infrastructure?
DarrenOC-Old
I'm new to this forum so please be kind 😀 . I'm looking for information on how Meraki implements 802.11r. Does it support it over the air side or over the infrastructure side. If it can do both how do I make it over the air?
Inderdeep
802.11r got a bad rap for a while because of security issues and fell out of favour.  I can't say I have personally used it for a while.  I think the roaming capabilities of client devices has improved a lot and it is not needed so much these days.
GIdenJoe
@PhilipDAththat is only the case if you use 802.11r with WPA2 Personal since the keying material is made from the same pre-shared key.
If you are using WPA2 Enterprise you'd better use 802.11r or you'll have roaming issues as a full authentication using 802.1X takes a long time.
@DarrenOC-Oldgreat question.  I'm hoping a Meraki employee will answer this.  If not we'll have to do a capture to determine the behavior.
