- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
6 GHz enable bug CW9162
As we all know: the CW9162 does not have XOR radios. So it has 1 fixed radio in 2.4 GHz, 1 in 5 GHz and 1 in 6 GHz. However I encountered a weird bug in dashboard where the default radio profile has the selection for the XOR radio on higher end AP's like the MR57, CW9166 are on 5 GHz.
This at least showed in dashboard that the CW9162's were not transmitting on their 6 GHz radio's. The moment I created a new radio profile and applied it to the CW9162's and then changed the XOR radio option to 6 GHz, the AP's according to the dashboard were starting to transmit on 6 GHz.
I did not have any 6 GHz device on hand to test if the real radio's were also not transmitting on 6 GHz.
Anyone had the same issue?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
We have similar with our CW9164s, 6 GHz not enabled in our reg. domain yet so Dashboard shows the 6 GHz radio supposedly sat in 5 GHz channel 161.
