2xSSID for different ISP (Guest and Employee)
JustRookie
I want to separate my network for guest and employee and I have 2 ISP routers now.
Just want to know that can I create 2xSSID, one for guest, one for employee and map each SSID
to different ISP router?
SSID Guest --> ISP 1 router
SSID Employee --> ISP 2 router
Do I have to be careful with anything?
Thanks!
RupertDot11
1 - map each SSID to a unique VLAN / subnet
https://documentation.meraki.com/MR/Client_Addressing_and_Bridging/VLAN_Tagging_on_MR_Access_Points
2 - use flow preference to select which source goes to which wan
https://documentation.meraki.com/MX/Firewall_and_Traffic_Shaping/MX_Load_Balancing_and_Flow_Preferen...
3 - don’t forget to make sure guest SSID users cannot communicate with each other.
https://community.meraki.com/t5/Wireless-LAN/LAN-isolation/td-p/59075
Thanks!
Have you got a switch which supports VLANs?
Yes, so one SSID to one VLAN 🙂
