2.4G only on one SSID and 5G on another SSID
wrespawn
Is it possible to assign one SSID to use 2.4GHz only and another SSID to use 5GHz only? I can't seem to find a way to do it.
Thanks.
2 Replies 2
NolanHerring
Yes
You have to contact support and have them enable the option for 2.4GHz only, which you will see under Access-Control
Then you can create an SSID and make it 2.4GHz only and another and make it 5GHz only (which should already be an option you can see).
Nolan Herring | nolanwifi.com
TwitterLinkedIn
yes. you need to contact support and ask to enable this
