2.4 Only
Adam
2.4 Only
I'm trying to troubleshoot some legacy devices.  Is there a way to setup an SSID that is 2.4Ghz only?  I've been playing with it for a bit and digging into the RF Profiles but I'm not making a ton of progress.
I believe if you open a case with support they can enable that as an option.  Otherwise no.
5 Replies 5
Adam
I contacted support and they enabled that option.  Thanks for all the feedback.  I didn't think about dropping the 5Ghz lower as well.
Vitojo
So it means it is not available unless you ask for it via a support case?
Correct.
kevinl
What Philip said. My workaround if it's just for testing, is to drop the 5Ghz power to the absolute minimum.
