xNetworkWirelessRfProfile() functions returning 500 Internal Server Error
Ausale
Hello, I using Python to automate some tasks, and I am unable to use any of the xNetworkWirelessRfProfile() functions. They all return "500 Internal Server Error".
Even the getNetworkWirelessRfProfile() is throwing an error, so I am pretty sure it has nothing to do with the content of my commands. I haven't had this issue with any of the other functions.
Anyone successfully using these?
2 REPLIES 2
Do you have any custom profiles?  The api does not return the default profiles
Ausale
I am only using custom profiles. I am passing the rfProfileId.
I am doing the same for "updateDeviceWirelessRadioSettings()" to override the profile for certain settings and this works just fine.
EDIT:
Even the "plural" function, without specifying a profile ID, doesn't work:
dashboard.wireless.getNetworkWirelessRfProfiles(
network_id
