priority setting in ap's
marodrig
I have 6 meraki MR46 ap's these are distributed in the company but we are having the problem since there are devices that do not connect to the closest ap, is there any way to move clients between ap's or some configuration so that it is done automatically?
https://documentation.meraki.com/MR/Other_Topics/Client_Balancing
At some client wifi drivers you can also tweak roaming aggressiveness
You could also look at your wifi desing/ lowering transmit power if they currently have to much overlap https://documentation.meraki.com/MR/Radio_Settings/Transmit_Power_and_Antenna_Configuration
marodrig
thanks for the answer and support
happy new year @ww @alemabrahao
As @ww said you can try to change some configurations, but remember that roaming is a client decision.
https://documentation.meraki.com/MR/Wi-Fi_Basics_and_Best_Practices/Client_roaming_and_connectivity_....
