can MX65 work as a access point?
bzind
is it possible to configure MX65 as a access point? if so can please someone link me the configuration guide?
Accepted Solutions
Aaron_Wilson
Re: can MX65 work as a access point?
The MX65 is wired only. The MX65W has wireless.
4 REPLIES 4
Aaron_Wilson
kYutobi
The MX65W unit you can configure for wireless as explained by Aaron_Wilson
NolanHerring
Here is a good link if you want to review/compare each models specs and capabilities
https://meraki.cisco.com/lib/pdf/meraki_datasheet_mx.pdf
Nolan Herring | nolanwifi.com
TwitterLinkedIn
fernando-buil
be careful with MX acting as access point; if you need MX radius accounting (p.e. if you have integration with external platforms for CMX, location analytics, etc) you'll have a problem because this functionality is not supported at MX products.
regards,
F.
