Wireless Authentication Failure with Radius
I am facing issue with all clients in some branches Association and authentication failure, log as shown below :
Associationtype='Association attempts' num='264' associated='true' radio='1' vap='0'
Authenticationtype='802.1X auth fail' num_eap='6' first_time='0.037280881' associated='true' radio='1' vap='0'
Authenticationtype='802.1X auth fail' num_eap='7' first_time='0.037280881' associated='true' radio='1' vap='0'
I am wondering what is the num_eap='6' ???
Many thanks in advance for help
Accepted Solutions
Re: Wireless Authentication Failure with Radius
Solution found by change the TLS on the RADIUS server to work with TLS 1.2
6 REPLIES 6
What does your RADIUS server log say?  If it allowing or denying the users?  If it is denying them what reason is it giving?
RADIUS server allow access !!
Did you have any idea what is num_eap='?' this numbers should be indication of something
I am seeing a similar issue, and am looking for information on the different type of EAP error messages mean:
type='802.1X auth fail' num_eap='13' first_time='0.037608748' associated='false' radio='1' vap='2'
type='802.1X auth fail' num_eap='13' first_time='0.067861253' associated='false' radio='1' vap='2'
type='802.1X auth fail' num_eap='14' first_time='0.036066128' associated='false' radio='1' vap='2'
type='802.1X auth fail' num_eap='13' first_time='0.074911531' associated='false' radio='1' vap='2'
type='802.1X auth fail' num_eap='13' first_time='0.033155373' associated='false' radio='1' vap='2'
type='802.1X auth fail' num_eap='1' first_time='0.074211961' associated='true' radio='1' vap='2'
type='802.1X auth fail' num_eap='13' first_time='0.042235861' associated='false' radio='1' vap='2'
num_eap='X' means the authentication failed at the Xth RADIUS packet exchange between AP and the RADIUS server.
Let's say the client shows num_eap='3', the authentication would go something like:
  1. AP sends packet 1 to the RADIUS server
  2. RADIUS server responds to packet 1
  3. AP sends packet 2 to the RADIUS server
  4. RADIUS server responds to packet 2
  5. AP sends packet 3 to the RADIUS server
  6. RADIUS server responds to packet 3 by rejecting the client
  7. The authentication failed at the 3rd packet exchange
Please refer below document for the packet exchange between the client and the radius server,
https://documentation.meraki.com/MR/Encryption_and_Authentication/Configuring_RADIUS_Authentication_...
let's say a client was trying to authenticate against the RADIUS server and for some reason, the authentication failed at the "RADIUS Access-Request: EAP Response Identity / Access-Challenge: EAP Request MSCHAPv2 Challenge" part, then you would see a log stating num_eap='6', because the authentication failed at the 6th packet sent to the RADIUS server.
Does that mean that every time you see num_eap=6 means that the client failed at the RADIUS Access-Request: EAP Response Identity / Access-Challenge: EAP Request MSCHAPv2 Challenge?, not really, as you also have to consider that the AP sometimes will need to re-transmit some packets.
So let's say that the AP retransmitted the first RADIUS Access request: EAP response identity 3 times and never got a response, then you may see an 802.1x failure event with num_eap=3, as the AP sent three packets to the RADIUS server and failed.
