We need a Wi-Fi count per tag/building
Jamieinbox
The business ask is that we get a daily report on the number of Wi-Fi connections in our buildings that we have labeled with the building tag. I cannot find a way to get this report from the Meraki reporting engine. I understand there are DNA spaces, but we are not looking for anything really by means of analytics. Maybe someday, but more a capacity report for planning and use. And yes- they want at least the Wi-Fi vision of numbers for COVID. We aren't looking to do wayfinding or anything I would consider 2nd tier analysis.
Anyone have any idea of how to get this info. Reports from Meraki would be great- or if anyone has done this with the APIs...
Thanks in advance. Comments and thoughts most welcome- including... did ya read this part of the manual? 😄
Accepted Solutions
Nash
Re: We need a Wi-Fi count per tag/building
I mean you'll have to read the (heckin) manual for part of this, because that's how we API, but:
You want to know number of devices that have associated to the wireless network in a given span of time?
I use Python so this is going to be Python-y.
If you need to know on a per AP basis, you could:
  1. Pull a list of APs (Pull on a per org or per network basis; check model[0:2] in Python to see if it's an MR)
  2. Pull a list of clients per AP
  3. Drop it in a spreadsheet using something like openpyxl
If you need it on a per-network basis:
  1. Pull network clients
  2. Check the SSID field for a value OTHER THAN null
  3. Drop list of clients into a spreadsheet using something like openpyxl.
Then just run this as a cronjob someplace, or do it on demand via CLI or a Flask app, and there you go.
If you have a bunch of networks, get fancy, make a table of contents, and do one tab per network in openpyxl. I need to refactor it badly, but I've got an example here that I threw together for a per org device inventory.
Caveat: I use kludges because I run into networks with a bunch of APs that aren't placed on a map and I am unable to place on a map accurately, so heatmap is not... so useful for me. You don't want to be me, maybe.
6 REPLIES 6
Network-dad
I found this article a while ago about Meraki Location Analytics https://documentation.meraki.com/MR/Monitoring_and_Reporting/Location_Analytics..
I know it doesn't quite give you a defined answer but it is a good read for what you are looking for...
Dakota Snow | Network-dad Linkdedin
CMNO | A+ | ECMS2
Check out IT Career Skills onIt Career SkillsIt Career Skills
Jamieinbox
Thank you- much appreciated!
Nash
There are two reports of interest.
Go Organization/Summary Report, and use the option to report on a tag.
Go Organization/Location Analytics and select the option to report on a tag.
Jamieinbox
Thank you, this is perfect. I am also hoping that I can get this report, with all other tags in one daily emailed summary report. I made a "wish" for that feature.Thanks for replying, I appreciate it!
Jamieinbox
This is excellent! I need to digest this a bit- but this is what's needed. I needed a bit of flexibility as I can get a report on a tag/building- but I really need one report summary (one page) for execs. I really appreciate your input!
