Restrict access by PSK and MAC?
WarrenG
Is it possible to restrict access to a wireless network by requiring both a passphrase and the MAC address being whitelisted?
You could set the firewall rules to a default "deny any".  Then a user would only get access if they knew both the PSK and you whitelisted them to override the deny.
Could you instead use WPA2-Enterprise mode with Meraki authentication?  Then each device would need both a username and a password, and you can disable an individual device easily.
https://documentation.meraki.com/MR/Encryption_and_Authentication/Configuring__WPA2-Enterprise_with_...
Another option is to use a unique PSK per device.
https://documentation.meraki.com/MR/Encryption_and_Authentication/IPSK_Authentication_without_RADIUS
10 REPLIES 10
Inderdeep
It would seem like using a PSK together with MAC address whitelisting should be a pretty simple option. Why is it that while Meraki's interface is very simplified, you can never seem to do the simple things that you might need to do?
Once you create the "deny any" rule (just one single rule), it's like 4 mouse clicks (just tried it) to whitelist a client from the client view.
I'm not sure how Meraki could make this simpler or easier.
Okay so I'm trying to track with you here. I create a deny rule on the particular SSID I need to lock down. How do you then whitelist a client from the client view?
It's called "Allow" rather than "Whitelist".  You can do it in several places, but the client's view is an easy way to do it.
https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Block_Listing_and_All...
Okay thanks Philip, I'm going to play with this and see if I can test it successfully. Thanks again for the help.
Paul_H
Within Wireless - Access Policy "Assign group policies by device type"... then select ALL the types and assign your PSK-ONLY-BLOCK-Group Policy 😉
Then within Network-Wide clients page - Add client section to override and assign a group policy to actually allow things 😉
WarrenG
Thanks @Paul_H, I'm going to try Philips method first and will come back to this if I can't get that working. Thanks again!
Paul_H
Hey @WarrenG !
I've definitely encountered this before and as mentioned above you could leverage a firewall to do it like @PhilipDAth and or leverage @Inderdeep 's ideas as well!
A 3rd option... (because Meraki is SO flexible 😉 ) You can:
--> Create an SSID with PSK and enforce a group policy to be applied that has deny ANY ANY.
--> Under Network-Wide, Clients - Add a client by MAC address
    --> Specify a unique Group Policy that grants access to that client MAC either globally or PER-SSID
--> Sit back like a Dashboard DJ!
Hope that helps as well!
