Print in Wifi
Print in Wifi
I have a printer connected to the data segment.
from the wifi I ping the printer and it responds without a problem.
but when adding to the form to a Windows machine it does not find it.
those computers where I can not add the printer are in domain.
I try to add the printer on a computer that is not in domain and I can add it without any problem.
That could be happening ????
Note: I do not administer the domain.
3 REPLIES 3
Re: Print in Wifi
I could not print on WiFi when I first got my APs installed. Is the access control configuration for that SSID set to Bridge mode? Bridge mode is what fixed it for me.
Meraki Alumni (Retired)
Re: Print in Wifi
It sounds like your domain admins may have pushed a GPO or policy that doesn't allow additional printers to be added.
If it works with a client connected to same SSID (or IP subnet) as the domain PC than that doesn't sound like a firewall rule or anything the wireless or underlying switch infrastructure is preventing.
Re: Print in Wifi
in case it's at the firewall level that could be because I was checking and I did not see anything strange
