It seems like our Meraki APs have a need to be randomly rebooted about once a quarter in our environment. No apparent issues on the dashboard, and they look like they are functioning properly, clients can connect, but they are just stuck, providing no network activity for clients. Send a reboot command, and voila, they start working again, connectivity restored. Doesn't appear to be model specific, I've seen it on MR33, MR36, MR42, and MR46E, all up to date on firmware. One or two cases, could just be a hiccup, but I'm seeing it more often than I would attribute to a random hiccup. Has anyone else experienced symptoms like this? And not that this is a permanent fix, but can you script a way to automatically reboot the APs on a schedule? Thanks
Solved! Go to Solution.
28.6 fixes this issue (at least it has for most people and support confirmed that the release is intended to fix it.
I experienced that a long time ago. I have a simple script on python that can help you (You can schedule to run it):
import requests
import datetime
now = datetime.datetime.now()
filename_prefix ='log'
network = "NETWORK-ID"
s1 = "AP-SERIAL_NUMBER"
#RUNNING REBOOT ON DEVICES
ap1 = "https://api.meraki.com/api/v0/networks/{}/devices/{}/reboot".format(network, s1)
payload = {}
headers = {
'X-Cisco-Meraki-API-Key': 'API_KEY,
'Content-Type': 'application/json'
#GENERATING THE RESPONSE CODE (TRUE = REBOOT OK /FALSE = REBOOT NOT OK)
response1 = requests.request("POST", ap1, headers=headers, data = payload)
#CREATING THE LOG FILE
filename = "%s_%.2i-%.2i-%i_%.2i-%.2i.txt" % (filename_prefix,now.day,now.month,now.year,now.hour,now.minute)
f = open(filename, 'w')
print('AP01', response1.text.encode('utf8'), file=f)f)
f.close()
Hi @alemabrahao. I'm not versed in python; but I have multiple networks I need to reboot the APs for. How can this script be edited to reboot the wireless APs for multiple networks?
If your APs are connected via Meraki switches, there's no need to use scripting to reboot / switch off APs - use MS Port Schedules. While you're switching them off, why not leave them off (overnight?) to save some energy and CO2s
https://documentation.meraki.com/MS/Access_Control/Port_Schedules
There is an API call to reboot a device, be it a switch or AP
You pass the device serial number to the API call
I can write some sample code to illustrate, would also inclue a post reboot check to confirm AP has come up be it PING to AP or another API call
