Hi All,
We've been toying around with mounting options for hanging MR86 with 2x ANT-25 antenna's. This will be hanging from a ceiling in a warehouse. We are using a custom made mounting bracket with the AP on the back and the Antennas on the front. I was wondering whats the minimum separation (if any) between the ANT-25s? Please see pictures for reference.MR 86 on back
Any guidance on this would be appreciated?
Kind Regards,
Kyle
Solved! Go to Solution.
When three times Wavelength apart is considered,
for 2.4 GHZ, Max Frequency = 2.5 GHz
Wavelength = 12 cm
3 times wavelength = 36 cm or greater apart is preferred
for 5 GHZ, Max Frequency = 5.875 GHz
Wavelength = 5.1 cm
3 times wavelength = 15.3 cm or greater apart is preferred
And So, it should be alright to place both at 36cm apart.
How to determine proper antenna spacing
As a general rule Southwest Antennas recommends customers place omni-directional antennas a minimum of one wavelength apart from one another, while three wavelengths apart or greater is preferred.
You can use the following simple equation to calculate the wavelength size at your operating frequency of choice:
Wavelength Online Calculator
https://www.southwestantennas.com/calculator/antenna-wavelength
For directional sector antennas, spacing the antennas at least a single wavelength or more apart (three or more is preferred) is also recommended by Southwest Antennas. However, due to the wide angle of the horizontal (azimuth) beamwidth and narrow angle of the elevation beamwidth of these antennas in comparison to their omni-directional counterparts, a few additional suggestions are warranted:
Hey,
Thanks for the information.
So to be clear, based on those results, I just have to make sure the antennas are 36cm's apart on the bracket? Based on 2.4GHZ. Am I correct to assume that this will okay for the 5GHZ as well?
Kind Regards,
Kyle
Wavelength = 12 cm
Wavelength = 5.1 cm
Sorry, one more question.
Would the 36cm be a gap between the two antenna's or would the gap be between from the middle of antenna A to antenna B?
Even 2.5 wavelengths apart is pretty good.
I like your design, I might steal it. Does it matter if the ant-25s are mounted vertically (cables running down, cisco logo at bottom right way up) or horizontally (cables running at side with cisco logo to right on a 90 degree angle)?
