I'm using 5 MR33s running firmware 25.13. We have had issues with Twilio VoIP and in our investigations have found our wifi network has latency spikes almost exactly every minute apart - it seems very mechanical in nature.
Does anyone have any idea what could be causing the issue or steps I should take to find the root cause of the issue?
The issue ended up being the location services on our Macbook pros being turned on. It turns out some of the options can cause this latency about once a minute when on wifi (the latency didn't show up when connected to ethernet). I turned off location-based suggestions and location based apple ads which seemed to do the trick.
Welcome to the Meraki Community! To start contributing, simply sign in with your Cisco account. If you don't yet have a Cisco account, you can sign up.
LITHIUM.Form.resetFieldForFocusFound();
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_630c5e1bc8a266","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_630c5e1bc8a266_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_630c5e1bc8a266_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_630c5e1bc8a266_2","feedbackSelector":".InfoMessage"});
LITHIUM.AjaxFeedback(".lia-inline-ajax-feedback", "LITHIUM:hideAjaxFeedback", ".lia-inline-ajax-feedback-persist");
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_630c5e1bc8a266","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
