Enable 2.4Ghz band only option
Anyone aware of a way to have an SSID broadcast 2.4Ghz only? I require this for my RF guns.
Accepted Solutions
Re: Enable 2.4Ghz band only option
Couple of ways you can do this:
  • You can contact support and ask them to enable the 2.4ghz only dashboard option for you.
  • Under radio controls, disable the 5ghz radio on the radios your RF guns would connect to
  • Enable band steering and hope for the best (not a great solution)
I'd recommend the first since it is the cleanest.
BHC Resorts IT Department
4 REPLIES 4
According to this site you can:
https://cantechit.com/2015/08/21/meraki-can-do-only-2-4ghz-on-wireless/
I have not done this myself so cannot vouch for the accuracy of the info provided.
What about on the MX appliance ?
Keith Baldwin
Technical Solutions Architect
Enterprise Networks
CCDE - 20170057
CCIE (RS, W) - 35439
You cannot disable this completely on an MX, unfortunately.  We seem to have found a workaround, though:
Minimize the power of the 2.4 GHz band to make it virtually invisible by setting it to 1 dbm.
  1. Go to Security & SD WAN -> Wireless Settings
  2. Scroll all the way to the bottom of the page
  3. Change the Transmit Power for the 2.4 GHz band to 1 dbm
  4. Click Save Changes
Of course, don't do this if you have any devices that cannot use 5 GHz, because those devices will no longer be able to connect.
