Cannot revoke a wireless client
Hi, I tried to enable captive portal login for guest, but cannot revoke the guest and let him relogin again. From the client monitoring page, the splash is "Not authorized", but the guest still can surf the internet. Please advise,thanks.
Accepted Solutions
Re: Cannot revoke a wireless client
Hi @Qing
I understand "Splash Page Frequency" settings might help you here.
Kindly check the following thread for more information.
https://documentation.meraki.com/zGeneral_Administration/Cross-Platform_Content/Splash_Page_Frequenc...
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
5 REPLIES 5
Hi @Qing
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
Thanks for your advice. yeah, this maybe helpful. I will try it. But the problem is we cannot revoke the client under client monitoring page. Looks not reliable.
Hi
I'm having the exact same issue. Were you able to revoke the client by changing the Splash page frequency? Thanks
same ,still cannot revoke the client from the network monitoring. Meraki bug!!!!!!!!!!!! Need expert to solve the issue.
shorten the splash page interval, can help a bit only.
