Can't move MR to Another Network
TLO3346
I'm trying to move an MR from one network to another but when I try to move it in Access Points, the list of available networks doesn't show the network that I want to move it to. Not sure why it's not displaying but I already have the MR connected to the other network LAN and the network that I want to move it to is a combined network.
Accepted Solutions
Re: Can't move MR to Another Network
  1. Create a new network of type wireless from the Network menu
  2. In the View All Networks screen select the new network and the existing combined network as select combine from the top:
7 REPLIES 7
AnythingHosted
Have you tried to remove it from its current network first?
Then, under the target network, go to Network Wide -> add devices. It should be listed here to add.
TLO3346
Will this make the MR lose it's config settings?
@TLO3346 if you go to the new network in the dashboard does it have a wireless section?  Combined network don't necessarily have all components in them.
TLO3346
@cmr It does not. I just assumed that it "creates" a wireless section when the first MR is added into it. How can I create this Wireless section before I move the MR?
UCcert
That’s bitten me a couple of times @cmr
Darren O'Connor | uccert.co.uk
TLO3346
@cmr It worked !!! Thank you for everyone's help.
