name | The name of an SSID |
enabled | Whether or not an SSID is enabled |
authMode | The association control method for the SSID ('open', 'psk', 'open-with-radius', '8021x-meraki' or '8021x-radius') |
encryptionMode | The psk encryption mode for the SSID ('wpa', 'wep' or 'wpa-eap') |
psk | The passkey for the SSID. This param is only valid if the authMode is 'psk' |
wpaEncryptionMode | The types of WPA encryption. ('WPA1 and WPA2' or 'WPA2 only') |
splashPage | The type of splash page for the SSID ('None', 'Click-through splash page', 'Billing', 'Password-protected with Meraki RADIUS', 'Password-protected with custom RADIUS', 'Password-protected with Active Directory', 'Password-protected with LDAP', 'SMS authentication', 'Systems Manager Sentry', 'Facebook Wi-Fi', 'Google OAuth' or 'Sponsored guest'). This attribute is not supported for template children. |
radiusServers | The RADIUS 802.1x servers to be used for authentication. This param is only valid if the authMode is 'open-with-radius' or '8021x-radius' |
host | IP address of your RADIUS server |
port | UDP port the RADIUS server listens on for Access-requests |
secret | RADIUS client shared secret |
radiusCoaEnabled | If true, Meraki devices will act as a RADIUS Dynamic Authorization Server and will respond to RADIUS Change-of-Authorization and Disconnect messages sent by the RADIUS server. |
radiusFailoverPolicy | This policy determines how authentication requests should be handled in the event that all of the configured RADIUS servers are unreachable ('Deny access' or 'Allow access') |
radiusLoadBalancingPolicy | This policy determines which RADIUS server will be contacted first in an authentication attempt and the ordering of any necessary retry attempts ('Strict priority order' or 'Round robin') |
radiusAccountingEnabled | Whether or not RADIUS accounting is enabled. This param is only valid if the authMode is 'open-with-radius' or '8021x-radius' |
radiusAccountingServers | The RADIUS accounting 802.1x servers to be used for authentication. This param is only valid if the authMode is 'open-with-radius' or '8021x-radius' and radiusAccountingEnabled is 'true' |
host | IP address to which the APs will send RADIUS accounting messages |
port | Port on the RADIUS server that is listening for accounting messages |
secret | Shared key used to authenticate messages between the APs and RADIUS server |
ipAssignmentMode | The client IP assignment mode ('NAT mode', 'Bridge mode', 'Layer 3 roaming', 'Layer 3 roaming with a concentrator' or 'VPN') |
useVlanTagging | Direct trafic to use specific VLANs. This param is only valid with 'Bridge mode' and 'Layer 3 roaming' |
concentratorNetworkId | The concentrator to use for 'Layer 3 roaming with a concentrator' or 'VPN'. |
vlanId | The VLAN ID used for VLAN tagging. This param is only valid with 'Layer 3 roaming with a concentrator' and 'VPN' |
defaultVlanId | The default VLAN ID used for 'all other APs'. This param is only valid with 'Bridge mode' and 'Layer 3 roaming' |
apTagsAndVlanIds | The list of tags and VLAN IDs used for VLAN tagging. This param is only valid with 'Bridge mode', 'Layer 3 roaming' |
tags | Comma-separated list of AP tags |
vlanId | Numerical identifier that is assigned to the VLAN |
walledGardenEnabled | Allow access to a configurable list of IP ranges, which users may access prior to sign-on. |
walledGardenRanges | Specify your walled garden by entering space-separated addresses, ranges using CIDR notation, domain names, and domain wildcards (e.g. 192.168.1.1/24 192.168.37.10/32 www.yahoo.com *.google.com). Meraki's splash page is automatically included in your walled garden. |
minBitrate | The minimum bitrate in Mbps. ('1', '2', '5.5', '6', '9', '11', '12', '18', '24', '36', '48' or '54') |
bandSelection | The client-serving radio frequencies. ('Dual band operation', '5 GHz band only' or 'Dual band operation with Band Steering') |
perClientBandwidthLimitUp | The upload bandwidth limit in Kbps. (0 represents no limit.) |
perClientBandwidthLimitDown | The download bandwidth limit in Kbps. (0 represents no limit.) |
