Search instead for
Android play store
Android play store
 I want to block google play store from Meraki, i add the https://play.google.com in block list but still play store is working.
Best regard,
Abu Zaid
2 REPLIES 2
Re: Android play store
Application blocking is best done by a firewall. Its very limited on what Wireless "Firewall and Traffic Shaping" does.
You should be able to just put:
play.google.com
In the block list.  Note that it doesn't take affect immediately.  And if has recently been accessed then the existing flow will be cached.  Once that flow expires the rule will take affect.  Having to wait 10 minutes is common.
Points Contest
Join us for a month-long contest with heaps of swag to win!
Learn More ›
