Action needed, no internet using PSK (WPA2) login
vilmantasr
Hello, with one SSID I always get requests in Windows 10, 11, Android, maybe Apple:  Action needed, no internet. Drivers, OS are latest. Problem only with this one SSID, settings are identical to others, so I don't understand why it always asks to open a web page to login.
You are not using one of those "personal" VPNs by chance?
As a punt, try removing all the Content Categories and see if the issue goes away.  If it does, add half of them back and re-test.  Repeat until you narrow down which content category is causing the issue.
I am most suspicious of "DoH and DoT" and "DNS Tunneling", so I would try removing those first.
7 REPLIES 7
KarstenI
What happens when you click “Open browser ..”? And are your firewall rules for this SSID blocking something?
vilmantasr
it opens http://www.msftconnecttest.com/redirect and OS shows, that internet is now connected. i think that is meraki firewall related, but which part is the question.
What is providing DNS, and what is providing the Internet access?
After connecting Windows is trying to access www.msftconnecttest.com and failing - so something is breaking that initial connectivity, even if it works later.
Are you using any software based firewall on the machines other than Windows firewall?
Do you have any web or content filtering software anywhere?
Google DNS, only Meraki firewall.
maybe there is to much:
Actually, before you do anything, if you are not running stable firmware or better on your MX, upgrade to at least stable.
vilmantasr
it seems that was the problem: I am most suspicious of "DoH and DoT" and "DNS Tunneling", so I would try removing those first.
