Hello all. I am very new to Meraki and still learning my way around. We have sever sites running different MR series access points and a lot of them are showing a disconnect that lasts about 3 minutes. It almost looks like it is on a schedule. I am not exactly sure what to start looking at. We just recently did the 28.6.1 update, and this is when I noticed the disconnects. Not sure if it was happening before or not. I have ran the built in "cable test" on our meraki switches, and the cable test comes back just fine. Any other ideas I could look at? I have provided some screen shots below. Thanks in advance!
MR76
Solved! Go to Solution.
Wanted to give an update. After talking with support, some of our APs were having fw reboot issues. It was all due to we were doing ssl decrypt on our upstream firewalls. Once we put in the meraki IP block to not decrypt, all of our issues cleared up.
Was it disconnecting before 28.6.1
Have you looked in the event log
Are you MX, MX, MR ; all Meraki gear
IP / management vlan conflict maybe ?
Do clients feel the disconnect
Not 100% sure on this one...
I dont see anything in the event logs of the AP. On the Meraki SW, I do see port status/port STP change logs repetitively.
All of our APs are MR series. Switches range from ms210 ms250 or ms350s
IPs are all statically set no IP conflicts.
I dont think so. I have not heard any complaints at least.
I can see they're rebooting. You need to engage Support.
@PhillipJFry Thanks for letting us know the cause, I was beginning to suspect is was Benders evil twin.
🙂 This time is was not Flexo.
We had a similar problem with APs on 28.6 , rolled back to 27.7.1 and it fixed the issue
We stayed on 27.7.1 for the longest time due to similar issues. With 28.6.1 and forward, just make sure you have 443 traffic to Meraki's IP block 209.206.48.0/20 and you should be good.
thanks Philipp, what is weird is that we do not filter outbound traffic ...
Are you back on 28.6.1?
I have it at a customer's and we have rebooting APs and so on >.< very frustrating
Yeah we are back on 28.6.1. Its been solid since configuring our firewall for the 443 traffic.
