AP placement on floor plans?
Ven
Two questions.
1. When placing APs on the map (standard google map setup) does their placement on the dashboard map affect their actual performance and radio management or is that just for us to view their approximate location?
2. Is there a way to upload floor plans and have them match the orientation of the maps?  I can't seem to get it working right.
thanks in advance!
kYutobi
1. No. It shouldn't affect radio or performance.
2. Circle is to rotate and square in bottom corner is for size. That should orient anything you need to match.
Enthusiast
5 REPLIES 5
kYutobi
Enthusiast
jdestef17
No, the placement on the dashboard should have no effect on actual performance. It’s just to create a visual. Also, when you’re using a floor plan, you can adjust the size to fit whatever you need. Just use the circle/square to adjust.
dalmiroy2k
It's only useful if you manage a large campus or enterprise and have dozens of units deployed. Same with the blinking leds option.
It´s a really good documentation tool which I don´t want to miss.
And, you can use the maps with the Location Heatmap tool:
Thanks for that.  I'm now seeing an issue where I see the APs, or I see the floor plan.  It's like the APs are hiding under the floor plan.  Is there a way to move them to the top or move the floor plan down a level?
Community News
