Group Policies para trafico InterVLAN
hgg
Hola
Soy un novato con Meraki, no logro que una regla que filtra el trafico InteVLAN entre 2 VLAN para un host especifico para el protocolo SNMP funcione, pueden ayudarme?
Mi dispositico esta en una VLAN de usuarios y el dispositivo que hace el escaneo SNMP (SNMPWalk) esta en otra VLAN que esta aislada del resto de las VLANS, puedo hacer que la VLAN acceda a la pagina web del dispositivo y pueda hacer ping al dispositivo pero no logro que el SNMPWalk hacia ese dispositivo funcione,
Alguna idea?
6 Replies 6
RWelch
SNMP Overview and Configuration
Meraki Device Reporting - Syslog, SNMP, and API
hgg
Thanks for your quick answer but my issue isn't with a Cisco Meraki device's SNMP, I'm trying to allow a device running SNMPWalk that is in a isolated VLAN to SNMPWalk a device in one of my users VLANS both of them have Group Policies applied, my understanding is that since Group Policies are stateless I should create rules in both VLANS in both ways (inbound and outbound), please correct me if I'm mistaken.
Thanks in advance
RWelch
Perhaps typing SNMPWalk in the search bar at the top of the page will get you to other posts with similar challenges.  I am not familiar with SNMPWalk unfortunately.
Mloraditch
Yes you would need to create appropriate rules. Are you trying with just port 161? Have you tried just allowing anything to the SNMPWalk host to see if that works?
hgg
I created rules for UDP and TCP for the ports 161 and 162 in both VLANs without success, this is why I'm seeking for help
Mloraditch
You can try and do some packet captures, or see if it works by opening up all traffic to/from the source of the SNMPWalk and then work from there, most likely with captures as well.
