unable to obtain IP
Mabouzid
unable to obtain IP
Dears;
i have connection between C9300X-12Y & JetNet6528Gf switch , all need configuration applied , it's noticed that when connect my laptop direct to JetNet6528Gf switch i am not able to obtain DHCP IP for the dedicated vlan  , the DHCP server located at firewall , i have got wireshard capture for DHCP message from C9300X switch just get dhcp discovery Message without Ack msg , although when connect my device directly to C9330X-12Y switch i am able to obtain IP automatic normal , i can't define where the issue exactly .
current C9300X-12Y firmware Current version: CS 17.1.4
thanks
Mloraditch
Is it possible your other switch has DHCP snooping setup incorrectly? Do your uplink ports match between the switches, same native vlans and allowed vlans if trunked?
Have you compared the DHCP discovery message from the JetNet to one from a port on C9300? Perhaps something is being tagged on the wrong vlan?
You can also try upgrading your 9300 to 17.2.1.1. I don't see a specific bug about DHCP that would apply, but support may ask you to do it anyway and it's always worth a shot IMO.
Mabouzid
thanks for your update , i expectedthat  also it would be DHCP snooping setup , i run ip DHCP Snooping trust command at uplink for JetNet6528Gf switch , ensure also from allowed & native vlan between both switches , when assign my device static IP behind the JetNet switch  connection working normal ,found that command at Jetnet switch <ip dhcp snooping database write-delay 0>  with Uplink port configuration <interface gigabitethernet24
switchport trunk allowed vlan add 1,200-201>
thanks
I believe that there is nothing that can be done on Meraki's side, I suggest that you open a support case with JetNet.
Mabouzid
unfortunitly i am not able to reach the other vendor support as the client bought the devices out side the country
