stp_tcn_errors - high rate of STP topology changes on all switches
allywenzel
Over the Thanksgiving break we suddenly started seeing a high rate of STP topology changes around 5pm on 11/30. We were not in session and no changes or updates were made to the network since before 11/25. Does anyone have any ideas on where else to look? How to troubleshoot if no changes were made on the network, what would cause this problem?
Thank you.
2 Replies 2
RaphaelL
Hi ,
Where is the root bridge of your topology ? I would look at logs on that device and start from there.
IvanJukic
Meraki Employee All-Star
Hi @allywenzel ,
I do see this type of situation often. Usally something changes to cause this.  That log "stp_tcn_error" 'Topology Change Notification". Meaning the Layer 2 path or Spanning Tree is changing where all traffic should go. Most of the time, someone plugged in something. Or in your case, most likley a cable or device is misbehaving.
As @RaphaelL reccomended, check you RSTP Root and make sure it is it is in fact the Root.
Use the following guides to assist in the investigating and mitigation.
https://documentation.meraki.com/MS/Monitoring_and_Reporting/Loop_and_MAC_Flap_Detection_on_MS
https://documentation.meraki.com/Architectures_and_Best_Practices/Cisco_Meraki_Best_Practice_Design/...
Cheers,
Ivan Jukić,
Meraki APJC
If you found this post helpful, please give it kudos. If it solved your problem, click "accept as solution" so that others can benefit from it.
